75 hp Johonson Stinger Thermostat
Stinger 75
I am replacing the thermostat on my stinger. The Johnson thermostat I purchased looks a little different than the original. The new one is made with a plastic housing and does not have the temp marked on it. Can someone help me find out if this is actually the correct thermostat. <br />The package has a P/N 396987 while the thermostat has the #397056 on it. I am a little weary of putting this on my motor. 1980 75 hp Johnson Stinger 3cylinder model# J75TRLCS<br /><br />Also, can anybody tell me what the poppet valves are for? Thanks Guys! Stinger 75
rickdb1boat
Re: 75 hp Johonson Stinger Thermostat
I'm showing part # 396987 as being the correct stat and is a 143* T-Stat. Over the years they sometimes change the T-Stats for one reason or the other. On my rude, they changed the water pump and T-Stat recommendation from the previous design. I don't know why your T-Stat has a different number than is on the box. Might want to call the dealer and verify, but I'm betting it's the correct one..
Stinger 75
Thanks for the info RB. I am going to double check with my dealer to find out about the different numbers. Thanks Stinger 75
DHPMARINE
Stinger 75 Originally #382385 was the stat #.This changes to #396987,so it interchanges OK.<br />DHP
