75 hp merc Tilt bracket tube
Teleflex steering cable is corroded into tilt tube (1998 75 2 stroke merc)I sawed off cable on starboard side of motor. Nut is off starboard side of steering cable. I want to take complete threaded tube out of the motor tilt bracket. The old streering cable section is fused into it. Will motor disconnect from tilt bracket if i do this? (I hope not). Does the threaded tube that the steering cable goes through also keep the motor connected to the motor mounting bracket? Thanks in advance for akll replies. And thanks for all previous replies to my last questions. Dennis G
