It has a Clinton motor.<br /><br />I can get the motor to run out of the water but can't get it started in the water. It is hard to start out of the water and must be choked to re-start even after it has warmed up. It will fire but won't stay running in the water. The diaphram looks to be in good shape and the float and rest of the carb looks good and clean. Any suggestions as how to get this motor to run in the water under a load?<br /><br />It has no neutral so the prop is turning while starting.<br /><br />thanks in advance.
