TriHullDano
- Jul 28, 2011
- 5
Hello All,
Looking through the service manual, for 757HA 75HP Chrysler outboard, it lists an obsolete tool to use for timing the engine.
However, the methods seems to be straight forward. Basically, insert the tool, rotate the engine to find TDC, reset the tool then rotate the engine some more until another mark, on the tool, lines up with the block. This distance indicates 32 degrees BTDC.
My question is what is that distance? I can easily find TDC and insert another tool, for example a #2 pencil, etc, and rotate the engine until the "new" tool has moved some said distance.
If that distance is unknown does anyone know the diameter of the flywheel on these motors? I don't know whether to measure for diameter to the outside edge of the teeth or to the valley between the teeth on the edge of the flywheel....?
Thanks,
Dano
Thanks,
Dano
