75HP evinrude running rough, bad gas?
markheth
I have an older 2 stroke 75HP Evinrude, and when i was out last weekend, I went through 1 tank of gas, the engine ran perfect. When i switched to the other 2 tanks i have, it would not stay running at all.<br /><br />At first I thought it may be the tanks (they are old metal OMC tanks), so i sipohoned some gas from these tanks to the empty tank which worked before. No difference at all, would not stay running.<br /><br />When i took the gas cap off the other tanks, there was alot of suction inside the tanks, i thought that may be the problem, so i tried to let it run with the cap off... no difference at all :( <br /><br />So now i think i have some bad gas... it looks ok to me, but it was last years gas. <br /><br />Is there anything else that could be the problem?<br /><br />Would it run that bad if I had the mixture wrong? What it it was too rich or too lean?<br /><br />I'm running 50:1, is that ok?<br /><br />Thanks!
voodoo
Re: 75HP evinrude running rough, bad gas?
50 to 1 is good, too rich fouls plugs and carbons rings etc, too lean eats engines.<br />Gas that has sat 3-6 months unstabilized should be considered unusable.
markheth
Can i stabalize the gas, or is it gone? My 4hp works perfect on this gas, funny the 75hp was so sensitive about it.
PDS
Gas is funny in 2 strokes. My chainsaw will run on 2 year old gas mix, but my old (76) 115 jonson won't run on gas that I bought 6 months ago. I suggest you loose the gas and start anew. You really can't renew the gas, but can burn it in a old carburated car or truck. Not recommened in fuel injected (oil is said to clog fuel injectors)My 2 cents. PDS
Todd Humphreys
Check to see if the pick up on that tank is partially cloged from rust or other debris. Those old metal tanks tend to rust a bit, and the rust (if it has water in the gas) can clog us the pick up screen over time. While you have all the gas removed look inside with a flashlight and remove the pickup tube and clean. Its worth a try!!! FYI :p
