75HP Mercury will not idle
vaboatdoc
Heres a great one. 1999ish (not totally sure on year) model 75HP mercury carbs have been rebuilt fuel pump rebuilt checked reed valves checked idle timing and wot timing all good did sync and link and all that good mess new plugs and checked compression and spark all are good. But engine will still not idle. Put it in fast idle and it does good but no idle at all. Please help if possible
Barnacle_Bill
Re: 75HP Mercury will not idle
When you rebuilt the fuel pump did you install the new style check valves?
vaboatdoc
finally got it figured..key switch had shorted and choke was sticking open and flooding it at idle
imported_Voyager
What are the "new style" check valves? My m50 (in-line 4 cyl., 50hp, 1982, "blue band", #6223380) has what I think is a fuel pump issue. The gasket that has the reed valves for the pump is black rubber (from mercury). When I rebuilt the carbs, I took out gaskets that were a tan plastic with some reinforcement in it. Did I toss "new style" valves and install old style, and if so, who sells the new style?
I now have idle issues that come and go. Motor idles fine while tilted up to negotiate shallows, dies when tilted back down. I suspect that it isn't pumping fuel well at idle, sometimes the hole shot is weak too...
Barnacle_Bill
There use to be a site that listed Merc TSBs but Merc made them take them down. I guess Merc doesn't want us to know what's wrong with their motors. I don't remember what all years it covered but what they were having you do is replace the rubber type check valves with plastic ones. The new ones come with the fuel pump kit that you can get from the dealer and it includes an explanation.
