I had no spark and found that i needed a new CDI. I replaced the CDI with a new one from CDI electronics and the motor fired right up as normal and operated great like it did before the CDI went bad. As it was idling after about 30 seconds the motor just cut off and i expected to see that i lost spark again but that wasnt the case, i also made sure that the fuel was getting to the engine and it was and i tried spraying starting fluid in the intake as well and still not even a sputter. My battery is brand new and has a charge around 13 volts and my compression is around 155-160 in each cylinder.
At this point im at a complete loss of ideas as to why this thing wont even try to run. The only times ive ever seen an engine cut off without sputtering was due to running out of fuel and a loss of spark. Is there something im missing?
