Re: 75hp only fires on 2 of 4 cylinders
tracker,<br /><br />I have this same motor and I would suggest getting a manual and a multimeter. Test the stator, trigger and coils before just slapping parts to her because that can get pretty expensive. When my stator went I got a weak spark on all cylinders and my motor wouldn't start. While troubleshooting I found a coil that had a corroded terminal and learned a lot about my motor.<br /><br />I'm not an outboard mechanic, but with a manual, a multimeter and help from the folks at iboats, I was back on the water.<br /><br />I would suggest using a mercury flywheel puller, which you can find on ebay, to pull the fywheel.<br /><br />TripleC
