Hello, had my old Ranger Fish & Ski on the water with success for the first time Saturday after alot of maintenance on the old girl. I've got a few more bugs to work out now but I was happy overall. My main concern is reverse. I really didn't try it until the end of the day when I dropped my buddy off at the dock to go get the truck. It is a '76 inline 6 150 HP by the way.
Basically, reverse seemed to not go anywhere and act like it wasn't engaging all the way. The prop would turn but way into the throttle movement.
Today, I had a chance to play with it on the trailer non running. It seems forward works when the control is forward to the first click like it's supposed to. Then neutral is neutral but spinning the prop will still sometimes have a minor ratcheting sound. If I go to the first click back (for reverse) it will be in neutral (prop spins free both directions w/ no ratcheting sound). Reverse won't engage until the throttle is way back by the ignition switch. I'm sure that this isn't normal.
I disconnected the cable and worked the linkage on the motor and I can get forward, neutral & reverse OK.
When I compare linkage travel going from neutral to forward, and neutral to reverse (with everything hooked up) the reverse motion at the linkage only goes about half as far as the forward motion ( so I know why I'm not getting reverse until a high throttle which I don't want obviously).
I just don't know if this is a classic symptom of a cable that needs replaced, bad controls, or lower unit (please NO but don't think so) troubles.
I also noticed there seems to be alot of slop in my shifter cable. I can wiggle the throttle cable @ the motor clamp and it's tight. If I do it with the shifter cable, there is alot of play back @ the linkage.
There is a "groove/slot" that the shift cable slides in maybe. It seems like something may be wrong here, When it's tight, it seems the arm it hooks to is still loose??? It's hard to explain and I can't seem to get anything under there to see if it's bolted/pinned or?????? I can see a spring that doesn't look very healthy though.
Sorry for the long post. I tried to be as descriptive as I could so you pros can hopefully give me some guidance. I'm going to study the manual & look @ a parts fische to see if something jumps out.
I do my own maintenance on everything I own but this is my first outboard.Thanks for any advice you can give me.
