hankll
- Sep 10, 2006
- 224
Motor was running the afternoon before I took it to the lake to go fishing. Next morning, at the ramp, it would not start. I assumed I flooded it. At home later, I have spark, on closed rim spark plugs. I am getting gas, but have checked fuel filter and bypassed fuel quick connector at motor, to make sure of no restrictions from those areas. Primer bulb seems to prime up ok. Choke clicks. I checked idle mixture screws and found them nearly shut off, something like 1/2 turn. I adjusted them out to 1 1/2 turns. The problem is before I did this I was originally trying to improve hole shot, which was a sputtering, nearly dying scenario. Slower throttle advance worked better, until I needed full throttle and still had the sputtering, starving routine. So I was attempting to enrich the idle mix by about 1/8 turn. Now I can't get a sneeze out of it, even when I bring the idle mix back close to shut off. I'm concluding the obvious that the float levels are off, or maybe timing is off somehow. But I don't know what I did to cause a timing problem to pop up. Suggestions?
