I just got my first boat,it's a 15'6" 1964 Chris Craft (corsair)glass with a 1976 70 hp johnson. It is bogging down when I hit wakes,it barely get up to 10 mph. if i pick up the motor and move it side to side it work's fine till the next good wake. It goes great when it is right(30-35mph with pep)(how fast should it go?)...I changed the plug's and the coil's. I also drained the carb's through the bowl screws, forcing fuel through them individualy, cleaned fuel filter,changed primer bulb and fuel line all this and it still suck's. Also it will die on acceleration to mid or full throttle after I shut down then restart after sittin for a few,i have to play with the throttle to get it right.
