'76 Merc 150hp T/T Hydraulic line location drawing
ClassyGlassy
I just recently purchased this running motor but the P/O took the hydraulic lines off the pump when he removed it due to routing of the lines/pump in his boat. He didn't mark the lines!! or the pump........
I just ordered a Seloc Manual for the motor, but if someone has a drawing they can post for me so that I can get the lines routed before it gets here next week I'd be much appreciated!
Thanks
ClassyGlassy
Re: '76 Merc 150hp T/T Hydraulic line location drawing
I also need to know which kind of fluid I should use to fill it all with........
Faztbullet
It doesnt matter where hoses go as they only fit one way on the trim manifold (small/large) just make sure you dont crossthread them or pinch them when pump is mounted. This unit takes straight SAE30 motor oil.
