OK, here's what I have: No Spark, narrowed down to Switch Box: Trigger and Stator Tests within range both Ohms and DVA. Nothing coming out to Green Wires ( to the Coil Packs ) from the switch box (Power-In no Power-Out). However, when the "Kill Switch" Wires are connected to a DCV to via Back/Yellow to Ground on a Multi meter, with the "Orange wire disconnected from the Switch Box ), as I have a newer Control Box and newer Harness to engine (Per CDIElectronics Diagnostics), I get a reading (Not much but some @ the 500v DC Setting) every time the key switch (ignition switch) is turned on/off/on/off/on, I get a reading (fluctuation). Which would indicate a Faulty "Ignition Switch" which is "Most Likely" frying the API Switch box? So,if I change the Switch Box out, it should just "Fry" again at $200+correct? So, change the Key Switch (Ignition Switch) AND Switch Box to resolve?
