76 mercury 3 cyl 65 hp- no spark
promonza
HELP! 76 merc 3cyl 65 hp type III ignition with no spark. this has been a very intermitent problem until now. history: installed used swich box for int. no spark, no change. carbon contact in dist cap breaks off and destroys dist and breaks belt. install new belt, used dist from boat salvage(told me it tested good), it backfired one time now I have no spark. tried old switch box, no spark. have power at red wire and white wire on box. have tried many tests (I am an auto tech by day) but cannot pinpoint. can anyone help me. thanks
ODDD1
Re: 76 mercury 3 cyl 65 hp- no spark
Monza, you are undoubtably looking at a failed trigger in the distributor body...the one you installed likely no good either...asuming you got timing close...the triggers were the weak spot in these systems, everything else held up well...
