Figured out my Fleetwin is a 57 and not a 58 as originally told. Fired the motor up and no water pumping. Shut it off and took it apart. The motor has sat long enough the impeller was breaking apart. Found the impeller housing had been replaced with what appears to be kit 763758. Also noticed prior owner installed the gasket below the wear plate. What I’ve read that should have been on top. Anyway long story short I’m looking to source the gasket and impeller. Does anyone know the part numbers. All I am finding is full kits. Any assistance in identifying the correct parts to purchase is appreciated.
