'77 1150 fuel pump rebuild
baide
I'm getting prepared to rebuild the fuel pump in my '77 1150. Does anyone have any clear diagrams or instructions on this task?
From what I can see, there is no need for any sealant other than the gaskets in the kit. Is this true?
Is there anything in particular I should be mindful of performing this task?
Barnacle_Bill
Re: '77 1150 fuel pump rebuild
Nothing to it. Just put it back together the way you take it apart with no sealant. Be sure not to reverse the check valves.
baide
any reason why I can't use stainless steel hose clamps for the in/out/vaccum lines???
Chris1956
I would think you should use all SS clamps.
