SkaterRace
Master Chief Petty Officer
- Mar 20, 2016
- 818
I was out today running WOT and the rpm dropped by about 1000 so I came off plane down to idle and waited a minute then tried again but only got up to about 4k rpm again then I figure I should go back to the dock on the way back (was running about 3000-3200 rpm) it dropped again down to 2500 so I pushed it a bit more to bring it back up to 3000 rpm due to fighting a head wind then. Coming back into the dock I tried to idle slow it down and when I came under 1000 rpm it stalled out. I am not sure what it could be, I will spend the weekend on it if not I am taking it in to have it fixed.
So I did a bit of reading and am now guessing I either have a carb issue or a fuel one. Gas is about 6 weeks old and I put seafoam into it for the first time before this trip. Also could it be because the motor overheated last time I went out which was due to a clogged intake ( I created a thread on finding a filter to solve this issue ). If it is because of the overheating what would likely solve it?
