Hello, I have a 77 Evinrude 115 hp on my 1978, 17.5 ft McKee Craft Southporter. I purchased this motor in 2015 as a replacement for the original 79 100 hp, which was used in salt water by previous owners, and had lots of corrosion issues. I only use the boat in fresh water, and so I found this 115 hp which came off an old bass boat. The motor is in surprisingly good shape for a 43 year old motor. The most recent compression reading was...
#1: 136 psi. #2: 137 psi.
#3: 134 psi. #4: 136 psi.
This motor has served me very well so far. It did develop an intermittent spark issue on the 1 & 3 bank due to a failing power pack. I opted to go with the CDI power pack, as I read mostly good reviews. A couple of the old coils were also cracked, so I went ahead and bought 4 new CDI coils at the same time. The replacements are CDI 183-4632, per the CDI website. While I have them sort of mounted, and they work great, the shoulders on each side of the coils are much bulkier than the original coils, and I can only get 1 bolt into two of them due to the coils interfering with each other. Has anyone else run into this issue, and if so, how did you resolve it? I don't like running these this way, but i hate to start drilling out extra holes in the coil mounting plate. I always try to keep things as original as possible. I am attaching some photos (I think).
Thanks!
https://photos.app.goo.gl/LHaou1X6BQwbovnb6
Thanks!
