texasatm2011
- May 30, 2010
- 22
I have a '77 johnson 140hp outboard that starts and runs great, the only problem that I have been having is when switching from neutral to forward/reverse. Let me see if I can explain it well enough!
When in idle position, I move the throttle just out of the neutral position I hear what sounds like the gears in the lower unit grinding. If I move the throttle a little more forward they seem to catch with a thud and then i'm crusing with no problems.
The same phenomenon happens when switching from neutral to reverse, except that the thud is so severe it shakes the whole motor! This usually occurs when I'm coasting up to the dock and I put it in reverse to slow down or back off the trailor.
I've tried to adjust the throttle cables but it doesn't seem to have helped much.
I just had the gears in the lower unit replaced last year so I don't want to screw them up again!
Any ideas as to what is going on?
Thanks for your help!
