Wee Hooker
- Sep 11, 2005
- 618
I reciently obtained a well used but deciently salvagable 77' Johnson 6 hp two stroke. It runs strong at top end, has equal (75#) compression in both cyls but has two known problems that keep it from being usefull: <br />1) The water pump quit after I ran it for only a few minutes. I know what has to be done here. I just dread trying to get a 30 yr old motor apart to get that impeller in. <br />2)The motor must be started with the throttle 2/3 into the running range as there is NO spark below 1/2 throttle . Basicly spark starts to show on my timing light when the idler wheel on the spring loaded arm ( from carb) hits the last part of the cammed protrusion on the piece under the flywheel ( that I believe) governs spark advance. Any lower throttle setting shows no spark at all and will not allow the motor to even fart. What are likely causes? I'm guessing Points? Shorted wire? <br />Any help or test hints appreciated. <br />Thanks in advance
