nomoreshore
- May 27, 2020
- 9
Newbie here. Prev owner said no power on water, took plugs out, turned motor over and water shot out of one plug hole. It has sat uncovered in weather for the last 2 yrs since. I'm trying to determine if the block is shot, or a head gasket issue. Figure I would start with a compression check. Can't even turn motor. Bendix is stuck in extended position, loosely engaged in flywheel. Just clicks trying to start. Any tricks to release Bendix ? possibly starter solenoid issue ? or does this point directly to pulling the starter out ?
