Thirsty Endgrain
- May 30, 2020
- 249
New and first boat. 1964 Glasspar Seafair with a '77 Johnson 70hp outboard. Top cover says "Stinger 75", but tag says 70EL77S. Anyway.
Still haven't gotten it to start yet, PO said it runs. But I'm finding a lot of questionables. There are little bolts missing here and there, carb cover was uninstalled, on and on. Just replaced the throttle and shift cables yesterday hoping it would get everything into position to start successfully, and I'm finding that I can't get the thing out of the forward gear.
I've read that the engine has to be on to be able to get it in or out of gear, so do I just do everything else to get it started and then try to move the shifter into the correct position? Have the shifter cable itself unhooked in the engine compartment so I can have the throttle cable set correctly. Tried pulling on the shift lever (underneath carb) while turning the prop with my foot but no dice. Next thing was gonna be to drain lower unit oil and pull for inspection.
If that's the right path forward, is there any chance it's as simple as dropping the four bolts and pulling lower unit free? Or is there more to it? Thank you.
Added: Some more pertinent information I just thought of, PO had replaced water pump impeller and a couple of other things. I think I've read that sometimes folks have issues with shifting after lower unit removal and install. Does the lower unit have to come down for water pump service? If so maybe it was reinstalled in forward gear and not started after that? I think I'll pull the lower unit regardless, just have a looksee, replace the gear oil, so I know it's fresh.
While I'm in there, what other seals etc should I have on hand to refresh? This is my first outboard so I'm learning all about them through this one...
