77 Jonny 70hp
Dbobjack
No fire on #2,coil is ok i switched trigger wires 1 to2 and 2to1 2 will fire 1 so I think that should eliminate trigger as the problem #1 trigger wire would not fire #2 I am guessing new power pak is not good no fire on 2 since it was installed anything else to check?
Dbobjack
Coil is good swapped wires with #1 and coil does fire it just seems like nothing is happening in pp,1/2 inch of spark on #1&3 dva at buss bar 350-372v for stator dva at pp for stator garbled up flashing numbers making no sense, there is higher than normal ohm reading on stator was approx 650 now it is 1000,+
Just replace the powerpack then.-----It usually fixes these motors.
