77 mercruiser 3.0 engine cracked water mainifold
phil rogers
I have an old mercruiser and I want some kind of sealer to seal bottom of manifold.Give me some ideas,It has leaked for a long time and I want to seal it better with some kind of sealer. Thanks phil
alldodge
What water manifold? If your talking the exhaust, that's not going to work
Bt Doctur
I`m still working on the liquid cast iron but it dosent look promising for cracks
HT32BSX115
The best manifold "sealer" is replacement.
mkfs9
Not worth trying to fix it up. Replace is the answer of you could get water into a cylinder if its gone bad inside.
Ayuh,..... Sounds like a freeze survivor I guess,...
Yer choice of epoxy with seal it up as well as anything out there,....
JB Weld comes to mind,....
