77 mercury 1150 no top end
Kailofsouls
I have a issue where my engine starts idles great seems to accelerate fine till I get to the last half of my throttle at that point it bogs out sometimes stalls rpms drop off and the boat won't lift up or plane out and can't get over 5-10 mph I just had her running at about 35 mph memorial weekend after cleaning and tuneing carbs prop is new replaced my battered 19p with the same pitch she used to run beautifully 2 years ago last year I had carb problems I thought this year I would finally get it right any help would be great thanks.
clueless75
Have you done a link n sync? Also, check the fuel pump if you haven't already. If you have a bad fuel pump it would explain why it won't go very fast as it isn't able to suck enough fuel
Kailofsouls
I can look into the fuel pump possibility but I never acutely took the carbs off just took out low speed screw and high speed access on carb and blasted it with carb cleaner but just incase how do I link n sink? Also every thing I find on my moter say it has one file pump but mine has two slightly smaller pumps on my block and filters located on the carbs on top of where the float is. I can't take any pics but my gas line comes in the cover goes to the top pump two lines come out one to the bottom pump one to my carbs bottom pump has one out going to my carbs.:noidea:
Chris1956
You might check serial number, as a 1977 1150 has a single fuel pump, located on the lower cowling, just behind the quick connect fuel line. There are SS screens in the top of the carb, but no banjo-style filters. Your motor sounds like an older model.
Check your spark plug leads for arcing to ground. Have someone pup the primer while trying to accelerate. If that fixes it, the fuel pump is suspect.
clueless75
The year is throwing me off a bit, two fuel pumps doesn't seem like a '77... What's the serial number?
Kailofsouls
Sorry it took so long for me to reply I don't have my own internet connection. Fule pumps are good I replaced them out of spite lol. Made no difference squeeze the primer bulb makes no difference. The carbs seem to be flooding but if I turn low adjusters in anymore the motor won't stay running.
