Re: '78 115 johnson
A leaking seal will "show". Lots of goo around the crankshaft,and flung all over the <br />inside of the flywheel.A compression loss will also be observed,especially the top jug.<br />If you lose compression,you lose the fuel pump's power to pump,causing fuel fuel starvation.<br />A weak flywheel magnet will give a weak spark,your plugs will foul very fast.<br />A surging RPM at high speeds could be a symptom of fuel starvation. Sputter could also be, but to a lesser degree. If the motor has been under repair for a long time, the fuel left-overs probably went bad in the fuel line,pick-up and bowl, varnishing everything up.<br />Just my 2cents.Hope you find it. Let us know what u find.<br /><br /> <br /><br />------------------<br />the Early bird get's the worm...So, he don't have to stop for bait.
