78 150 drive shaft
jy118lfd
Took my lower unit off to work on and my driveshaft splines that go into powerhead are worn. Not bad but worn. What are the options to fix this? <br /><br /><br />I am currently looking for a used shaft and the crankshaft does not look bad but will check with the new shaft. <br /><br />Is this the only option or is there a way to replace splines in the crankshaft without disasembling the entire powerhead?
wilde1j
Re: 78 150 drive shaft
Try Trixie's Marine in Bayville, NJ for a used driveshaft. Not practical to rework yours.
