I am looking for info on 78 235 johnson carbs. Mine seem to run lean at lower rpms and I have cleaned them 3 times all orfices are clean but one idle jet is stuck in top carb and looks like someone screwed it up tring to take it out. I have a set of v4 140 carbs but I dont know if all the jets are the same. If I can get the jets and sizes I may be able to use these. The motor runs fine at any throttle above 1/8 and under load you can hear and feel the motor stop missing and the power comes on. It will run perfect all day long at higher rpms and throttle<br />Any suggestions would be greatly appreciated
