ahicks
- Sep 16, 2013
- 3,957
When cold, water appears to be pumping normally, with good flow from the indicator. Within a few minutes, water is reduced to a trickle coming from indicator, eventually stopping with some slight steam instead, and the engine starts getting hot.
Complete water pump is new, water pipe is snug on both ends, compression on both cylinders match, and this is a fresh water engine with no signs of corrosion. Engine is new to me so I have little history on it, though it does have some discolored paint indicating it's been over heated at some point.
Never seen anything quite like it. If nobody has any ideas, I'm getting ready to pull the head and the water jacket to see if there's blown (cooked) gaskets or impeller chunks blocking the water flow. Wondering if anyone has seen anything like this that could save me the trouble (exploratory surgery).
TIA, -Al
TIA, -Al
