txbandit44
- May 11, 2008
- 182
this thing seems to run great winds out nicely but when I start the motor. I have to pull the start lever up and leave it there. If I push it down slowly it will idle down but not low enough that I would want to engauge forward or reverse. If i push down to far it stalls out and I dont seem to have a happy medium on idle speed. I would say with out a tach i go from 1000 rpm to stumble and stall. It will not run under 1000 rpm.
I am pretty sure its a low speed idel adjustment but I am unsure how to adjust it on this motor. I have a 72 65hp FSM for a reference at the moment but the idle adjustments are different so I am stuck. I cant get a service manual till monday and I want to fix this tomorrow morning so I can finally get this thing in the water after 7 months of tickering. This is all I lack other than a kill switch issue. Can some one point me to a write up or give me instruction on fixing the idle?
thanks
thanks
