Hi all I have a 78 Chrysler 45 hp outboard after running out of gas and switching tanks the motor would run only on 1 cylnder no problem with the gas or the tank after checking compression found both cylnders have about 115lbs compression both have bright blue spark new plugs but with both plugs out turning it over the bottom cylnder is spraying gas out about 1' while the top cylnder doesn't ahve any visible spray, after putting the plugs in it will start up but the bottom cylnder is flooded with tons of gas causing it to not fire. <br />Any Idea's have never had a problem with this motor leading up to this.
