Hi <br />I have a the above mentioned engine and have replaced the impeller. I just bought this motor and it was not pumping so I replaced the impeller. after lake test it only stream out the tell tale every once in a while and actually seemed to quit streaming at all. when I run it in gear at rpm there is steam coming from exhaust ports It did seem to shutoff once and I believe it was the heat sensor shutting it down if there is one on this motor. Any ideas about what I should look for..I also have a 95 9.9 2stroke merc that used to pee really well and now it has a diminished stream. It seems to be coolikng ok just not flowing well. I inspected the impeller on this motor and it looks great..<br />sowhat do you guys think maybe a block restriction on both on thermostat problems maybe?<br />thanks for your help?
