78 Merc 140 lower unit
jakeruppert
I am waiting for a service manual I ordered, but can anyone tell me if I can change the drive shaft bearing with out disassembling the lower case gearing. If so can I get some instructions?
Scaaty
Re: 78 Merc 140 lower unit
Wait for the manual...(and be prepared).. the whole thing must be pulled apart..no easy fix. Lots of work, all must be pulled, shimming must be correct. Not an amateur job. Need correct tools too. Take it to a pro
Chris1956
Jake, You might like to look around for a used LU. You should be able to get one for <$500. Rebuilding of yours may cost more than that.
