James_Ketcham
- Jul 25, 2019
- 43
serial 4862371, just mounted this engine on my boat and put the muffs on it to try it out, it took about 5 revolutions and it started right up and idled fine, there was however no water out of the tattle hose. it ran about 10 second then i shut it off. pulled the lower unit, checked the impeller and although it was molded into the direction of the rotation, the fins were still flexible , not cracked. my question is, shouldnt this have even dribbled water out the tell tale tube? does this engine have a thermostat? should i try to put a low pressure air hose to it and blow through it to see if it is blocked? looking for information on what to check and where to go from here.
also found this pin laying in the cover and not sure of it's use or where it came from.
