new to me ihad it started & it ran fine out of water w/ears trailered it 20 miles then 2 days later tried to start and nothing. i opened the cover & found frayed wires (deteiorated casings) ifixed the bad wires i now have no spark but motor cranks fine/has new fuel and its getting it since it was first started i changed thetrim pin to the highest position for trailering does this unit have a mercury switch i t bradfishd@yahoo.com hink it grounded while i crankd it cause small + wire on solenoid was touching block did ii burn up ignition switch or otherwise pls advise thanks brad
