Having troubles with motor running out of fuel at high RPM's or under heavy load. It also seems to lack a little power out of the hole. When it begins to act up, pumping the primer bulb brings it out of it. Have replaced fuel pump diapragm and check valves. Cranking compression is 130 across the board. Fuel tank vents operate. Lines and primer bulb are new. Engine sat for about 5 years but do not know how it ran previous.
