'78 Mercury 115 will not shift into reverse.
jbigtrout
The motor does go forward but will not go into reverse. Looked at the linkage and it seems to be working. Any help is appreciated.
coastalrichard
Re: '78 Mercury 115 will not shift into reverse.
Hmmmmm...have you been doing any LU work, as in lube change, impeller or pump work? Also, post the SN for the motor.
jbigtrout
No LU work on it yet. The person I bought it from said he had replaced the impeller late last summer. The SN is 4867013.
Sugo
Is the shift linkage out of adjustment? Unhook the shift cable at the outboard and see if you can manually shift it in reverse. if so take note of the position the linkage needs to be to engage reverse hook it back up and see if the travel is far enough to engage revers. If not adjust shift cable. (small increment) Confirm adjuster is working correctly. Consider that I am not a mechanic but have had a similar issue when considering my advice. A bent shift pin in the leg can also cause this. Or RPM not dropping low enough at idle for shift dog to engage.
jbigtrout
okay, working now. Thanks for the help.
