78 mercury 1400 with a 1961 800 fgs lower unit
angelvigil03
I'm wondering if some can help. I bought a pontoon boat with a 78 mercury 1400. I was trying to perform some maintenance on the outboard and could not find the water pick ups for the impeller anywhere. Turns out some one put a 1961 merc 800 fgs lower unit on the motor. The water pick up is the Trim tab and has holes in it. I took the boat out on the lake and everything worked great. Except I noticed the water stream wasn't as good as I think it should be. So I am trying to figure out which water kit to use for this unit. Ultimately I'm wondering if this lower unit will last all together. I'm looking for a original lower unit but am wondering if anything was modified to adapt this older lower unit. Appreciate any help.
angelvigil03
No Title
Here are some photos of what I'm talking about.
Faztbullet
A toon with a trolling plate??? some of the earlier units had a square shift shaft instead of spline so they may have switched them in lower unit
angelvigil03
Yeah I think someone was trying to race this pontoon ? So your saying someone might of just switched the lower casing ? Is there any reasoning why someone would do that ? I just bought this whole set up for $3500. Was planning on investing money into a new motor but the merc runs good. I'm planning on opening the lower unit it up soon and I'll post pics. Want service the impeller but not sure which one I need ?
emckelvy
It will take the same impeller as what would have been used on the 140hp: 47-89984T 4 or Sierra 18-3017.
One thing to note is that some of the older L/U's had a groove machined for a pin in the driveshaft, this is what would drive the impeller. Newer L/U's had a flat ground into the shaft and a regular impeller key used. This is the better setup, so if yours has the flat on the driveshaft, make sure to upgrade to a 28-8M0032834 key.
If the driveshaft has a pin-drive setup, make sure the impeller has a snug fit on the pin and doesn't rock around a lot.
If the pin looks worn, replace it, it's still available: 17-8M0034466.
HTH & G'luck..........ed
angelvigil03
Thanks for your help I appreciate it. Going to order the parts and open it up. Might need some help as I've never done it before.
