Hi I'm new here and I was hoping someone knows how to properly set the timing on a 78 402 Mercury 2 cyl. I discovered a Killswitch wire voltage so disconnected it and go it fired up finally. Then started advancing the timing which was off till the Mark lined up and it's still idling at 1800 rpms. Hitting on 5 degrees like it said in the manual but idling at 1800. What am I missing? The throttle plate is closed. Any help would be appreciated thanks.
