Hello
I have a 78 merc 800. It idles a little rough, and likes to die when I put it in gear. I have pulled the plug wires while it's idling and it seems the #4 cylinder is dead. Has 120 psi compression. When I pull the plug wire off, it has tons of spark. I have checked the resistance on the wire and it is 0 ohms. I have switched the spark plug with another cylinder but the #4 remains dead. Is it possible that the lower carb could be dirty and firing the #3 but not the #4? This is the only thing I can come up with. I spent 10 years as a diesel mechanic but have little experience with outboards. Can anybody lend some advice here? The motor has good power once it's up and going, however at some rpm ranges it does tend to sound like it's got a miss in it. I also recently had the power head off to replace the exhaust manifold and water jacket manifold gaskets. The pistons and such looked ok, didn't see anything that looked out of place. I talked to the previous owner and he never had an issue with the boat. He claims the gas is probably about two years old. I was going to replace the gas as well and add some sea foam. Any thoughts?
