Re: '79, 115 Mercury timing pointer??
Had a couple bad days at work, didn't get a chance to work on motor.<br />I did mark TDC # 1 cyl. and marked fly wheel timing for the primary pick up, & did the same for spark adv., set idle. When for a ride. Motor runs 110% better!<br />Clams Canino, I still have not ruled out bent rod! I try to approach from as many angles as possible to verify, or rule out different diagnosis.<br />Would pulling the head & using a micrometer, to compare with the other cyls. The distance, at TDC.<br />to a straight edge across top of cylinders?, or with the press. test being as it is, all cyl. within 4 PSI be sufficient?<br />Thanks for all the imfo.
