Re: 79 140hp Johnson
both times the same thing happended but different cylinders. Not sure which cylinder the first time because we took it straight to the marina and had to have 2 and 3 head put on (after the flood). This time #4 cylinder burnt on the right hand side of the cylinder (if you are facing the motor behind the boat). Plugs were Champion and fuel 93 oct. Fuel was the other week. The marina marked timing on the flywheel at 28 so we don't know timing at 5800. When the motor was rebuilt the man that built it told him to run it on double oil for 20 hours. Which we did. Then we put 2 sets of plugs in also (it burned the others out). We switched down to regular oil and it had been running good. Last weekend the boat shut off while running wide open at about 4500 rpms. Then it started back up and ran good 3 miles then it stopped again, cranked again and would not plane after all. Put new plugs in again, ran good for 4 miles and it burnt one side of the cylinder. Any suggestions is really appreciated. Thanks for all help!
