roughshot
- Jul 14, 2010
- 164
Ok. After reading post after post about prop selection and all the great advice, I have come to the conclusion that no two prop selections will be the same and that I am still uneducated with respect to my prop needs.
Here is my scenario;
22' Starcraft Mariner - Stripped down for being a layout tender boat for Duck hunting.
I am replacing or removing everything from the boat including, foam, deck, console and seats.
This boat loaded with have a 3 to 4 guys, let say 1200 lbs dressed.
200 decoys - 200 lbs
Gear/Safety - 300 lbs
Layout boat - 250 lbs
Total - 2000lbs (excluding boat & Motor)
add another 2500 lbs for Motor, Fuel and Hull
I'll be running a '79 150HP V6
I don't know the RPM range.
What is my best prop selection for this Load? What about when I'm not Loaded and just out for a ride?
Thank you in advance.
