Re: 79 305, 383 mercruiser...
I know carbs but, is there a certain place to start, or just tear it apart and clean it all out? Thanks BondO!
In my experience if I have dirt in one part of a carb or another... chances are that more of it needs attention. I do better if i just go the full rebuild route when in doubt.
Note that what you're describing can also happen if you have water in the gas. when you pull the carb or top off depending on what carb you have on there, look and see if you can see any droplets of water. If it's fuel contamination related, youll just clean the carb all out then crap it up as soon as you put it all back together again. not that I've done this in the past two weeks or anything... :redface:
after the first time I wound up removing a very large amount of water from my fuel tank... and then going through the carb again after changine or cleaning everything in the fuel system... there was almost a gallon of water that settled out by the time I got all the fuel out of the tank, etc...
