79 35HP Evinrude Stall at low RPM's in Neutral
larrybr45
Started out of winter 1st day ok, a little sputtering. Late in that day, I went tubing, and between riders had to turn off the engine and restart during the afternoon. After about 6 times, engine would not fire up, just cranking so I had to be towed to my dock.
A few days later, the engine fires right up, but only stays running at high RPM's in neutral. When lowering rpm's, it dies. I have new plugs/gas.
I am thinking carb, BUT I do not have a repair manual to know where the carb is much less what to do with it (assuming this might be a cause)
Any thoughts?
thanks
