79 DT2(2hp) suzuki outboard
jwh
Trying to find out if this motor is water cooled?Thankyou very much John:)
jwh
Re: 79 DT2(2hp) suzuki outboard
Do not need to be rude. Thanks anyway. John
deejaycee_2000
sorry didn't mean to come off rude .... the 2hp suzuki does not have a clear pea stream like bigger outboards, but you will see a fine mist from the 2 "nostral" holes on the leg ....
jwh
O.K.
Thankyou a lot.Sorry about the misunderstanding. Hope I can ask you another question ? I am not getting any spark. Could the safety shutoff Button be stuck? I can't seem to get inside this switch button. So I cut the 2 wires to it and put those together bypassing the switch and still no spark. Hope this was a correct way to check the safety off switch? Hard to believe something is wrong with the coil or stator assmbly because the powerhead ,carb, looks brand new. If I need to pull the top off the stator assmbly I am not sure of the process to remove the cover Thankyou again for your help. John
