79 johnson 9.9 misses
this thing is getting to me...
I had a problem where it would loose power at full throttle and only run full choke 1/3 speed.
rebuild carb, new fuel pump, new gas tank and supply hose. adjusted according to carb kit. It starts a little harder than it used too, but over all seems to run ok.. but has a miss it acts like it has sneezed.. running smooth and the whole thing shakes with a little wheezy "cha" throttle response is slow too.
now I have not run this underway yet, I fill a garbage can and run it in that. dont like to paddle... all adjustments are made at running temps it seems to leak a lot of black goo out the prop. I might not have run it enough to really heat up and burn all that off becasue of the full coke condition.
