replacing driveshaft bearing along with all others, when driveshaft came out it just kind of came apart. Question is, the shim/ring on right closest to bearing, shim or price of bearing? It is much thicker than shims, about .093, and is not same width as the shims inside to outside, it matches that too bearing ring there in all dimensions. My new bearing did not have two grooves on the race which would be another ring. Wouldn't think it would have to have a shim that thick. Any advice appreciated. Thanks
