RinkerTinker
- Sep 18, 2012
- 31
Hey iboats,
I have finally succeeded after two years of battling my state's title office, and have received the title to my boat. This has given me ample time to read, learn, and dream about my boat project. When I bought the boat I thought there was only a few little things to fix, little did I know this would turn into a complete rebuild and redesign. Not long after I bought the boat, I noticed the engine had "sat down" on the deck. So, I decided to take the engine out and investigate. I assumed the mounts were rotten and was right. At this point, as many of you know, the project then spiraled out of control.... waterlogged foam, bouncy floor, rotten stringers, broken tabbing, etc. Luckily I have spent years reading these forums and felt up to the challenge.
Thanks in advance to everyone who posts and responds on this website. I have removed the engine and all the guts and will add pictures of the whole process sometime. I am hopefully getting close to being done with the grinding and I have a few questions.
I would like to reinforce the transom by building it as one piece the full width of the boat but the rear is not flat. Does anyone have any tips as to how to rebuild the transom as one piece?
I would like to leave the hollow center stringers except for the wood strip on the top which I will replace. Can I grind down the weak or cracked areas and fiberglass over them to the hull without removing them... "super reinforcing"? As well as the place that your feet go so I do not have to remove these things completely?
Thanks J
Thanks J
