79 rude 85hp tilt trim problem with big pics
letsplay
I have a 1979 85 hp evinrude on my 1980 hp-154 glastron that is having tilt trim issues.I can hear the pump running when pushing switch up or down but the tilt arm/piston does'nt always move. I have flushed and filled with hydraulic oil after placing it completely up filling then brought down then up filled more...etc. After filling correctly it still gets stuck either in up down or somehwere in the middle but the tilt pump still sounds as if it is running when moving toggle switch up or down. I am new to owing an outboard motor but I am mechanically inclined...if any one has any suggestions or help I would be very grateful. Please just explain steps as I am a newbie.:confused:
jonesg
Re: 79 rude 85hp tilt trim problem with big pics
Make sure the manual release valve is very tight, should be 45 in lbs.
Get the service book too, its in there.:)
www.outboardbooks.com
Jim d
Hey there, do you know the oil to fuel ratio for a 1979 85 hp evinrude motor?:)
